my pathy starts then stalls within 10 secs
it starts then runs fine for ten secs then maybe runs rough then dies like the fuel line or filter is clogged or line was pinched shut,
anyone run into this?? it did die once at the gas station after i started it and popped the hood to check the trans fluid, then drove 5-6 hundred miles, got home went fishing next day ran fine parked it and here we are
ecm gives 55 all clear.....was gonna clean MAF and check the IACV but wasent clear on checking it or cleaning it so any help would be greatly appreciated
is there anything to do with the fuel pumps that would let it run for a few then kill the pump???
Guest
