Cylinder Heads
1994pathfinder
I have an old set of heads from a 91 maxima and i was wondering if they would work for my 1994 pathfinder, since the motor is basically the same.
You know what engine it is? Pretty sure you have the VG30E, and if it has the same, it will probably work just fine.....but idk maximas enough to tell ya...
But, i'm pretty sure we commonly use maxima alts, so they MIGHT have the same engines...
From what I understand, the VG30E Maxima engine has the same core (bottom end and heads), but everything else such as electronics and injection system, etc are different to work with a front wheel drive application.
