Knock, ping, pre-detonation, etc.?
rydsno
And suggestions on what will cause knock, ping? Can the timing belt be a factor? It's getting changed next week. I've done the plugs, gapped OK, done cap and rotor, seafoam yesterday, oil change done, vac lines good, no engine codes. The ping happens under load, especially uphill, and I know it's OK for some ping, but this seems excessive. And the idle seems higher than normal, sometimes staying above 1000 rpm for a long time, doesn't seem to want to come back down.
side note: engine also seems to vibrate when accelerating heavy and getting up to higher rpm's
:scratchhead:
Edited by rydsno
