CO94LEV6 Posted September 25, 2009 Share Posted September 25, 2009 So this last weekend was pretty busy. Got a 3" body lift installed and waiting on delivery of a Kennisaw front bumper so that I can install that as well. Question is... with the Kennisaw bumper, I opted to not install new blinkers in the bumper and figured that I would convert the front marker light into a combination marker light/blinker. Has anyone else done this conversion? Are there any simple tricks I should know prior to going down to NAPA to try and find a bulb/socket combination that will work. Link to comment Share on other sites More sharing options...
Mookie Posted September 25, 2009 Share Posted September 25, 2009 So this last weekend was pretty busy. Got a 3" body lift installed and waiting on delivery of a Kennisaw front bumper so that I can install that as well. Question is... with the Kennisaw bumper, I opted to not install new blinkers in the bumper and figured that I would convert the front marker light into a combination marker light/blinker. Has anyone else done this conversion? Are there any simple tricks I should know prior to going down to NAPA to try and find a bulb/socket combination that will work. Hello, Yup, that conversion has been done by quite a few. I'm almost certain there is a write up on this site. Do a search and hopefully that will shed some info for you. I used an 1157 socket (replaced the stock one) and used a dremel to make the socket fit. There is a much easier way to do this - and the write up iirc is the way to do it. Link to comment Share on other sites More sharing options...
CO94LEV6 Posted September 25, 2009 Author Share Posted September 25, 2009 I searched before posting.... Will look again and maybee I'll find something. Link to comment Share on other sites More sharing options...
