Alignment question: toe specific
Did a search on toe and alignment - couldn't find exactly what I was looking for so I'm hoping some of y'all can help me out.
Background: I have a stock 1998 Pathfinder, just added some used (but very good condition BFG AT KO's). Just finished installing new struts, strut bearings, repacked bearings and check all other front suspension components for play/wear. (FWIW, the front end is MUCH quieter now! :jig: )
Assumption: I know caster is not adjustable, nor is camber (with the stock strut bolts). So really, all I need to adjust is toe.
Question: What is the proper toe setting? Zero? 1/8" toe-in? 1/8" toe-out? I have a good set of "toe-plates" so if I'm not/can't adjusting anything else there's really no sense in bringing it into a shop.
Thanks again for all your help!
Al
