3" or 4" body lift
jumper
I wished they had a 4" body lift here in the US! You could fit 33x12.50s on a 15x8 wheel with some slight trimming. No difference between the 3" and 4" body lift except the 1" and that extra 1" inch helps out a lot. Hell, I would probably go for 35x12.50s if I had a 4" body lift on.
Guest bryan89
you might have to do some extra finagling with the brake lines and speedo cable. i noticed it was kind of tight with the 3" lift. you would almost definately need a raditator drop kit though. some guys get away without it with the 3 inch lift.
