Removing heat shield on exhaust manifold - question?
Jetmugg
I've got an exhaust leak that seems to be coming from the passenger's side (US spec) exhaust manifold area. I have read the threads about cracked manifolds, and suspect that mine might be cracked.
In order to check the manifold, I need to pull the heat shield. Taking a look under the hood, I can't tell if I will need to remove the O2 sensor to get the manifold heat shield off, or if the one around the O2 sensor is a separate shield. I have not attempted to remove the heat shield yet, I wanted to do a little research here first.
Is it possible to remove the bolts holding the heat shield to the manifold (I think there ae 4 of them) and then completely remove the shield from the manifold? Or does the O2 sensor have to come out and let the lower heat shield somehow slide up and out?
Any help would be appreciated.
SteveM.
