Check Engine Light?
robert
Okay. So me and my friends are driving down the highway when I noticed my truck trip over itself pretty much So I slow down a little then realize CEL is on? Also it came on the other day to... but than I changed batteries so it was reset?
Well I don't know where my manual is right now. So My question is how do I run the codes?
95' Nissan Pathfinder SE v-6
All I know is how to turn the screw on the ECU but not sure exactly how to read the code?
Okay code 33:heated oxygen sensor.. Okay so now i feel dumb where's the the sensor located at
not dumb......most folks don't know where it is......
that's the o2 sensor. it is under the driver floor and is screwed into the exhaust. you can follow the wire all the way up and over the transmission to a set of "plugs" on the passenger side fenderwell. :aok:
Edited by Slick
awesome! well i cleared the code after i checked it... seems to be running good...
also another question why the cel comes on..
sometimes when i go play in water or mud it bogs down and pops and seems to miss??
One time i know why it did because i inhaled water in the intake.. "crossing a small river" not such a good idea...
