Warn Hub, Bearing service etc?
dragonfly
Ok I have completed most of the repairs I plan to do for now, Heres the list
Upper and Lower Ball joints
OME Front, rear shocks and springs
Serviced the wheel bearings when knuckle was removed
Warn Hub install
BFG 31x10.5 and new steel wheels
The problems.Vibration
I thought the alignment may be the issue or wheel balance. After reading a few threads about the Warn hubs I noticed that I need to put the snap ring back on the shaft. I did not see anywhere on the instruction where it said to do that?? I did try but the shaft would not move out far enough to get it on so I assumed it was not required. Would this also caouse a vibration?? Anybody else have this problem?? I will try again on Friday.
HELP
Thanks
HMMM
FUN FUN FUN
Discovered That the bearings on the right hand side have slight play.. I will repack and re torque. Possibly replace.
This may have stemmed from my curb collision at a roundabout when we had a foot of snow last year which led to a bad rh lower ball joint..ETC
RH Brake caliper is seized
Very sloppy Idler arm........I need my Calmini kit
Learning is interesting and stressful $$$$$
Snap rings installed on the inner groove. For the Warn Hub install
Warn Hub install
HELP
Thanks
What kind of steel wheels did you go with, do you know what the backspacing is? I'm looking in to getting new wheels and I have the same tires on Legos right now.
