german996 Posted October 30, 2007 Share Posted October 30, 2007 Hi everybody, my temp gauge was very bouncy and my tach was working fine, in my 95 PF a/t, now they switch after the Pf was garaged for a while, now the temp gauge works perfect and the tach barely woks, which make me believe taht there should be a ground issue, so to remove the cluster from the dash after removing the two top philips screws what else need to como off in order to remove it? I already did a search and went to the HOW TO section. thanks for any help or guidance in this matter, also would like to change my bumpers from chrome to black , any suggestion in this matter? thanks German996 Link to comment Share on other sites More sharing options...
95shakinPF Posted October 30, 2007 Share Posted October 30, 2007 (edited) 1st-The very bottom trim piece under the steering wheel has 2 screws at the very bottom of the dash.Remove these first. The top of this trim snaps into place, so pull! 2nd-After thats out of the way you will see the other screws holding the cluster trim in place. Remove all 4 of those to get the cluster trim off. 3rd- Then you should have 4 screws holding the actual cluster in. That should be all, besides the 4 wire plugs hooked to the back of the cluster. Trust me, I know all this because mines out of the dash right now!!! Good Luck! I love my pathy, but 95's have some crappy clusters!! Edited October 30, 2007 by 95shakinPF Link to comment Share on other sites More sharing options...
german996 Posted October 30, 2007 Author Share Posted October 30, 2007 Thank you for your guidance,very helpfull, will try out tonight.... german996 Link to comment Share on other sites More sharing options...
