cluster removal question
german996
Hi everybody, my temp gauge was very bouncy and my tach was working fine, in my 95 PF a/t, now they switch after the Pf was garaged for a while, now the temp gauge works perfect and the tach barely woks, which make me believe taht there should be a ground issue, so to remove the cluster from the dash after removing the two top philips screws what else need to como off in order to remove it? I already did a search and went to the HOW TO section. thanks for any help or guidance in this matter, also would like to change my bumpers from chrome to black , any suggestion in this matter?
thanks
German996
1st-The very bottom trim piece under the steering wheel has 2 screws at the very bottom of the dash.Remove these first. The top of this trim snaps into place, so pull!
2nd-After thats out of the way you will see the other screws holding the cluster trim in place. Remove all 4 of those to get the cluster trim off.
3rd- Then you should have 4 screws holding the actual cluster in. That should be all, besides the 4 wire plugs hooked to the back of the cluster. Trust me, I know all this because mines out of the dash right now!!!
Good Luck!
I love my pathy, but 95's have some crappy clusters!!
Edited by 95shakinPF
