My '98 Is Deteriorating...
I used a sort of rubbing alcohol on the rubber weather stripping & it looks brand new now...I wouldn't suggest it though, I have no idea if this is bad for, all I know is that it worked.
A little alcohol on the rubber is fine as it cleans the dirt and crud off. However, it also dries out the rubber and accelerates its decay.
You should follow up with some treatment that includes a plasticizer replenisher. I use a combination of Black Magic's Pro-Shine Protectant followed up with some of the same company's silicone-based Tire Wet for finishing.
