eglaisi_91pathy Posted November 4, 2006 Share Posted November 4, 2006 I need to find the location of the daytime running lights module in a 91XE. Anyone know where it is? Link to comment Share on other sites More sharing options...
clark Posted November 4, 2006 Share Posted November 4, 2006 (edited) Its in the right fender beside the battery. theres to two plugs going in to it .let me guess olny one light come on with the day time runing lights? Edited November 4, 2006 by clark Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted November 4, 2006 Author Share Posted November 4, 2006 just replying to say I found it right after I posted. Thanks anyway. BTW, no, not only 1 light was out on the DRL... both were. 1 was out on highbeam. The eBay module from Nova Scotia fixed both those! Link to comment Share on other sites More sharing options...
LD50 Posted November 4, 2006 Share Posted November 4, 2006 mine needs replacement too... where did you find it?? Link to comment Share on other sites More sharing options...
clark Posted November 4, 2006 Share Posted November 4, 2006 you can just take the thing apart and resolder the broken jonts in side and it will work again it is very common for the solder joints to crack on these Link to comment Share on other sites More sharing options...
LD50 Posted November 4, 2006 Share Posted November 4, 2006 i remember it was replaced on our old pathfinder as well.. but where can i find the actual unit? Link to comment Share on other sites More sharing options...
clark Posted November 4, 2006 Share Posted November 4, 2006 its in the right fender right beside the battery Link to comment Share on other sites More sharing options...
LD50 Posted November 4, 2006 Share Posted November 4, 2006 (edited) is it the black box INSIDE of the fender? Edited November 4, 2006 by LD50 Link to comment Share on other sites More sharing options...
clark Posted November 4, 2006 Share Posted November 4, 2006 yep and it has two plugs in Link to comment Share on other sites More sharing options...
LD50 Posted November 4, 2006 Share Posted November 4, 2006 Awesome, thanks alot! Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted November 5, 2006 Author Share Posted November 5, 2006 yup, 2 phillips head screws and thats it. its right beside the battery in a hole in the fender. Im not sure if you need to do this, but I took out the battery, since I know there was rust where it sits (worse than i thought) so I fixed that a little. It was really easy taking out and putting in the module. Link to comment Share on other sites More sharing options...
