95Finder
About 95Finder
  • Birthday 01/27/1982
    1995 Pathfinder
    Rarely Go Off-Road
Contact Methods
  • AIM
    Fogg101
  • Website URL
    http://
  • ICQ
    Rochester, NY
  • Interests
    Cars, Own a Toyota Supra and Nissan Patfinder
95Finder's Achievements
NPORA Regular (2/5)
  1. Well can't get the damn thing out and I don't have the cash to pull the head and have someone use an EMD machine on it. I guess I will just get a new exhaust gasket and bolt the manifold back on for the time being. When I get the cash I guess I will have to pull the head and take it to a machine shop. Thanks for trying to help.
  2. Lol, carbide won't drill into it, I am going to grind the bolt down with a tungsten carbide tip(the only thing I found that will cut the extractor) for my dremel until the tip of the extractor is no longer present. Then I will try to drill and extract the bolt again, if this doesn't work then I will probably just end up drilling it out to 5/8 as Slick did and tap it for a bolt, wish me luck.
  3. Anyone??? I know other people have done the same thing, it's inevitable when your drilling out studs. Why did this have to be one of the Pathfinders few faults?
  4. I am replacing the studs on my 1995 Pathfinder, one of the studs was broken off so I couldn't get vice grips onto it. I drilled into the stud and started threading the bolt extractor into the hole. The bolt extractor snapped off and part of it is stuck in the middle of the stud. What are my options? Can I buy a carbide drill bit that will drill back into the stud? If I bring it to a shop will they be able to somehow get it out. Or do I need to remove the head and bring it to a place that removes fastners using EDM? Any help would be appreciated. Thanks.
  5. It was fine yesterday, today after I changed the gear box out it started doing it, I think it might be because I didn't line up the splines as well as I should of and the steering wheel is actually turned a bit to the right when the wheels are straight. I guess I will pull the steering gear out again and line up the splines so the wheel is straight when the wheels are straight. Thanks for your suggestions.
  6. What's up, I just replaced my Steering Gear Box because it was leaking fluid...now when I press on the brakes I can feel the truck pull to the right...do I need to get an aligment after I change the gearbox out? Why would it only pull to the right under braking? If anyone has any suggestions I would appreciate it. Thanks. Jason
  7. Good to know, hopefully one of my local yards has a steering box for me...once I install the new box, how do I bleed the PS system? Also about how much am I looking to pay for the box with everything I need from the Junkyard?
  8. Thanks for the info, so to remove the steering gear arm do I just remove the large nut on the bottom and slide the shaft out? Where would I get the shaft re-hardchromed, or could I just get the shaft honed down a bit so it is smooth again? Anyone else have experinence with this problem?
  9. Whats up, I noticed that I am leaking fluid from where the steering gear arm attached to steering gear. I can see a rubber gasket where it pivots. I have tried using PS stop leak but it hasn't worked. Does Nissan sell this gasket by itself? I can't seem to find anything at Autozone or Advance Auto Parts. Please help if you know a part number or have had this same problem. Thanks.
  10. I had to mount some tires on rims for my brother today and put them on so I didn't have time. Hopefully I can dissasemble the hubs tomorrow. I'll keep this thread updated with my findings and some pics. Later.
  11. Well it seems as though its mostly while I am turning, it only happens after I have used 4wd. Last night it was happening consistently. I parked the truck for the night and today it hasn't happened at all. I am sure if I engage the 4wd and disengage it today the sound will start back up. It seems to be fine once it sits overnight, kinda strange.
  12. Yes I am backing up to disengage the hubs. Just seems like when I turn the hub is catching the splines and hitting it out causing a loud clunking sound. I just did my rotors and packed the hubs and all the other components with grease but maybe one of the seals is shot and is letting dust/dirt/water in. I will check it out. Later.
  13. I am having some problems with my 4wd on my 95 Pathfinder. When I shift out of 4 wheel hi and back into 2 wheel hi it doesn't seem like something in the 4wd system is disengaging on the front passenger side correctly. It almost seems as if the axle is barely disengaged and sliding in and out of the hub, causing loud clunking noises everytime the wheel rotates. It will only happen when I am starting off up to around 15mph. Has anyone had a similar problem. Did you just remove the hubs, clean and regrease them? The noise occurs after I use 4wd....but if I park it for the night, the noise sometimes stops until I use 4wd again. If anybody has any tips please let me know. THanks.
  14. I searched the forums for a bit last night to try to see if anyone else has had the same problem I was running into. The thing is people post their problems but don't usually follow up with the fix. At first I thought I had filled up with some bad gas because the engine would stall out while I was driving...it would take as long as 5 minutes before it would start again. Yesterday The fuel pump would work intermittently, so I pulled off the fuel pump access cover in the rear cargo area and saw the problem. There are 4 wires that run to the fuel pump, they all are connected to brass posts with a ceramic button on top of them. The 2 wires on either end were corroded and one fell off when I moved the wiring harness. I chipped off the ceramic covers and cleaned up the brass posts with some emery cloth, I then soldered the wires back to the cleaned up posts and WA LA the car starts and stays running. These wires must have been so corroded they would have a connection sometimes and other times they wouldn't. Hope this writeup helps someone. Later.
  15. My front drivers side power window has not worked since I bought the Pathfinder. I thought it was the switch at first because when I push the up button I can hear the motor trying to put it up and sometimes actually see the window get pushed up a bit. When I push the down button nothing happens. Today I went to a salvage yard and got a new switch assembly...it does the same exact thing that was happening before. Is my motor bad or could it be the wiring? I just don't understand why the motor would still be able to go up but not down. Thanks. Later.
