rayace
    2002 Pathfinder LE
    Screwdriver Mechanic
    Choose
    Choose
rayace's Achievements
  1. No neck filler recall according to the dealership for this year. Anybody know where I can have the codes pulled for free in Ontario ? If not, I might look into buying an OBD2 scanner.
  2. I removed the plastic piece in the wheel well and the tubes running to the filler neck are made of steel with no chance of getting coated in dirt. They are eventually connected to rubber tubes which lead to the evap cannister, vent control and electrical wiring. Still have not had any solutions for this problem with the exception of changing vent control valve and/or evap cannister. I need to have the engine codes checked to see what error is provided and see if it is related to the filling problem.
  3. It does it at every gas station, every time I fill up. I just removed the vent control valve. The little white plastic tip inside appears to move up and down without a problem. Vehicle is running well, just annoying light and filling up problem. I will take apart the hose near the neck and see how it looks.
  4. I have been having problems with filling my gas tank over the last year. Also, my Service Engine Light has been on and off over the last year. When filling the tank, it will only take it at a very slow rate. If I remove the handle all the way out and allow the gas to continue to flow, I can actually see it coming back up the pipe. I have read forums which suggest changing the vent control valve and evaporator cannister. Others suggest a valve in the tank might be stuck which prevents gas from flowing out in a rollover situation. Can this valve be cleaned and reapplied or does it need replacement ? Any idea on the cost of valve ? Thanks in advance.
