HoserRacing
About HoserRacing
  • Birthday 09/18/1969
    1993 Pathfinder SE
    Rarely Go Off-Road
    Chatsworth, GA
HoserRacing's Achievements
  1. Ok, trying to look around everything, I thought it was an A/C line, didn't realize it was the return line. Do I have to change the return line as well, or can I just cut the pressure line to slide it out of the bracket? Thanks for the tip on the steering shaft joint!
  2. Quick question (hopefully), I'm working on changing the pressure line on the power steering, and there is a bracket behind the front passenger wheel on the frame that has the metal part of the line as well as an A/C line going through it, and I see no way to pull the hose out. Do I just cut the hose & pull it out of the bracket & zip tie the new one in place? Thanks for the help!
