ToddtheRobot
    94 XE, 3 inch lift, 31x10.5 tires on 15x10 wheels, KNN Air Filter,
ToddtheRobot's Achievements
  1. Got into my truck last night, turned the key and nothin. Only my headlights will come on. No dash lights, no fuel pump pumping, no brake lights, no interior lights, just headlights. Battery has plenty of power.If anyone can help it would be greatly appreciated.
  2. So would the front sit down a little lower? Can you just crank the torsion bars to match? Also, a little more info...... What year and model JGC? Estimated time? Tools needed?
  3. I have a 3"lift right now, would the JGC coils actually lift even further or no?
  4. I think it's to make up for the puny horsepower I have 31's on mine with the 3" body lift and 15x10 wheels. Just curios if it's the width or the height of the tires that cause the problems.
  5. Just curios about your lift. Is that 3 inch body and 3 inch suspension? I am wondering if I can fit 33's with my 3 inch body lift .
  6. YAY!!!!! It was indeed the corroded fusible link And to think I only had to pay 250 for towing and a new distributor But hey, Doris now runs great So, for all of you guys who may have this problem sometime, buy the Chiltons manual and trace the wire from the inectors to fusible link back to the battery and check for corrosion. I am also developing a new theory on Pathfinder mechanics....... I will call it Todd's Razor. It states that if something is wrong it is normally the cheapest and easiest part you can find.
  7. Well, I think I may have found my problem. I looked at the wiring diagrams for awhile last night, and noticed that there is an in line fuse running from the injectors to the battery terminal. Traced the wire and had continuity from the injectors to the inline fuse, but no continuity from the inline fuse to the terminal. Looked a little harder and the connectors were corroded as hell. Got'em soaking in baking soda paste right now. Hopefully that will do her.
  8. Well, out in a new distributor, and it still doesn't work. Checked the wiring harness to the ECU and everything looks fine. The fact that the ECU says nothing is wrong kinda makes me wonder if my ECU is actually working correctly. It seems to be going through the modes correctly and shows 55. Does anyone know if an ECU will do that even if it is bad? And does anyone know about how much a salvage yard normally charges for an ECU for a 94 M/T 4x4?
  9. yeah, I've done that a few times. The pump is working great, I replaced the Fuel filter, plugs are getting spark, starting fluid starts and then dies. I was reading about the crank angle sensor, and it seems like it may be the problem. I know it works with the fuel and ignition system. I don't know if there is anyway to test it once it's been removed.
  10. Sorry, yeah. It came up 55. No Malfunctions. I am really lost, and don't want to have to take it to a shop.
  11. Positive that it's pumping. Disconnected it from the filter, and the pressure was good. I just think that since it suddenly stopped working, it couldn't be the O2 sensor or dirty injectors.
  12. i tried the starting fluid yesterday and had no luck. haven't checked my fuses, but i don't think it's a fuse. does anyone know much about the computers in the pathy's? Today the fluid worked, but it died after spraying stopped. Know anything about the crank angle sensor? Or any other ideas? It's driving me nuts.
  13. Thanks man.Just checked the ECU and it flashed me a 55. So, no malfunctions. But, I have gotten it to start with the starting fluid, it's just dying immediately. I think it might be the crank angle sensor. Does anyone know anything about these? Or how to test it?
