Nissanfreak36
About Nissanfreak36
  • Birthday 12/27/1989
    I have a 1991 nissan pathfinder 4WD with 31x10.50 and rock crawler 15" steel wheels, new paint, and heavy duty brush guard with a flowmaster turn down exhaust!!! ;-)
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
    Gulfport, Mississippi
Nissanfreak36's Achievements
  1. I just ran it on a switch to the cab, I didnt put the fan clutch back in it but i did keep it just in case and it helps keep it cooler it you have an aluminum radiator and use to have a copper radiator ill get pics up soon for ya
  2. washin the old pathfinder later
  3. that was the only one in the whole yard that had one lol
  4. I was at the junkyard and happen to come across a very large fan on the front of a 1995-1997 nissan quest, i took it off costed me 10 bucks and bolted it to the front of my truck after i ran the fuse and the switch to the cab and the cooling difference is great. I had to cut the shroud a little bit to get past the steering box but it works and the fan has a large shroud connected to it for easy installation. If you have any questions just let me know.
  5. Well its been a while but i ran into an issue that I solved and wanna let everyone know, well my truck was overheating when i had tha a/c on the solution that i found was adding a 12" fan in front of the condenser, its a tight fit but it helps so much in this heat. Everyone just send me an email and let me know how you been doing these past couple months!!!
  6. its really bad when the a/c is on it doesnt stop
  7. thanks i really apprieciate all the help, and by the way have any of you guys experienced a whisle when you put an aftermarket intake on it?
  8. How many quarts does the truck take stock and how much should i put back in it if i drain it?
  9. I have a 1991 pathfinder xe 4x4 173,000 miles, when it idles it sounds great but when you put it in gear and go it sounds like something with a valve like its not primed. Its not exhaust but the exhaust manifold gasket on the driver side has never been changed EVER!!! but if its not that then what do yall think it could be? And i bought some lucas oil stabilizer, is it a good idea to add this on the next oil change??? Or is that a sign that the manifold gasket is about to give in??? Please let me know, Thanks.
  10. My transmission doesn't do that yet but what would be the best brand to do it with, I think valvoline makes it and also what weight do I need to use for the tranny. How many quarts do i need to use for this job?
