CD4616
    1989 v-6
    Screwdriver Mechanic
CD4616's Achievements
  1. Hi Tom, I wish it were that simple, but it's an auto and i have tried shifting into neutral and every other gear, even tried moving the 4-wd shifter into different positions. I'm still stumped??? Starter is 98.00 exchange, fixing to try it unless someong comes up with another possibility. Thanks
  2. Hi All, I need some help figuring this one out. Starting a couple weeks ago my 89 Pathfinder starter only works every once in a while. When it works, it works fine, but when it doesnt work it does nothing, no noise at all. I have pulled the starter off, (that was fun) and bench tested it and it worked fine. Cleaned it up with a power washer and degreaser, dried it out with the air compressor and tested it again and it still worked fine. Hooked it up to the Pathfinder wires and it still worked fine so I put it back in and drove it for another 3 days, working perfect, no problems. Went out the next morning and nothing, no click except for the relay, nothing. I let it sit for 3 days and then went to pull it up to the shop and it started like a charm, drove it up to the shop, killed it and started it 4 times, then on the 5th try got nothing. I have charged the battery and even tried jumping it but still nothing. I'm stumped, should I replace the starter or could it be something else??? Any and all comments on this matter will be appreciated.
