CountEjacula
    1988 Pathfinder, 4x4, 3.0, 5 Speed
    Skilled/Experienced Mechanic
    XE
    Louisiana
CountEjacula's Achievements
  1. For anyone that finds this, I managed to fix it. I was getting voltage across the line for my "fusible link", but I ended up pulling the fuse anyway and reinstalled it. Lights kicked on no problems. Super weird.
  2. Hey Slart, I've got the fusible links "bypassed" and I've just installed a couple of inline fuses. Previous owner messed that up a little so I figured it's best to make it fused. Is there anything there that could cause other problems?
  3. Hello everyone, Got the starting issue sorted on my pathfinder, and drove it for a bit, now I don't have any lights, nor do I have any accessories. Exterior and interior. All my fuses are good, and all my relays are clicking. Ignition switch is sending power, where it should. Is there something I'm missing? Any and all help would be appreciated. Thank you.
  4. Hey Slartibart, thank you for the wiring diagram! It does have the stock alarm. I actually found the issue. There was a tiny split in the black/yellow insulation close to the firewall that I did not see. There was enough juice to get the starter relay to click, but I guess not enough to function. Thanks for taking the time!
  5. Hello everyone, I'm scratching my head on this one pretty bad. Recently picked up my '88 pathy, after missing my 93. I've got a no crank issue. I can bump start just fine. After fixing some wiring "repair" the previous owner did, I was able to get it to crank and start when I installed a new starter. Currently I've got a new starter installed, wiring is good (unless there is something I'm missing), I have the neutral safety switch bypassed, and a brand new Optima Redtop. I do not have a crank. When I turn the key I get a click out of the relays and that's it. I've got 3 starters and they all bench test fine, I just find it odd that after I installed a new one the first time it fired right up. Any and all help would be appreciated. Thank you.
  6. Hello everyone, I'm scratching my head on this one pretty bad. Recently picked up my '88 pathy, after missing my 93. I've got a no crank issue. I can bump start just fine. After fixing some wiring "repair" the previous owner did, I was able to get it to crank and start when I installed a new starter. Currently I've got a new starter installed, wiring is good (unless there is something I'm missing), I have the neutral safety switch bypassed, and a brand new Optima Redtop. I do not have a crank. When I turn the key I get a click out of the relays and that's it. I've got 3 starters and they all bench test fine, I just find it odd that after I installed a new one the first time it fired right up. Any and all help would be appreciated. Thank you.
