04BlackR50
    2004 Pathfinder Chinhook Stock
    Rarely Go Off-Road
    Chinook
    ontario
    Canada
04BlackR50's Achievements
  1. Will do, thanks again for the info I really appreciate it. Hard to find info on stuff like this. Glad I found the right guy! Will clean it first and update in a few days. Sent from my iPhone using Tapatalk
  2. Ok if that’s the case then I won’t be messing with that, would you recommend just changing out the fluid and adding some lucas stop leak to try swell up the seal? Sent from my iPhone using Tapatalk
  3. In the FSM it shows that both the seals are at the end of the extension tube. Sent from my iPhone using Tapatalk
  4. Ok thanks for the info, would you just recommend to put some fresh fluid in the diff and possibly add some additive to make the seals swell a bit and possibly slow the leak? Not looking to do a full diff rebuild on a $2k truck. Sent from my iPhone using Tapatalk
  5. Where did you find that info, I’ve heard some people say you can remove the side shaft and in the schematic it looks like the inner seal is at the end of the extension tube. Just trying to get a straight answer before I start pulling it apart. Thanks Sent from my iPhone using Tapatalk
  6. Thanks I took a look at that, most likely the inner oil seal, most people say the outer grease seals last 2x as long but they will both be getting replaced anyways. I’m the diagram there’s is 2 bearing collars that say they need to be replaced, can they be reused if not damaged? Sent from my iPhone using Tapatalk
  7. Hey all, have a clicking from the front when car is moving and turning so I think that's the cv axles, so l took a look at them and also saw a leak at the end of the axle on the passenger side where it meets up with the cv axle. Is this is axle seal leaking? If so has anyone done this job. Considering I will be taking out the old cv axles I can get it all done in one shot. TIA Sent from my iPhone using Tapatalk
