juno1228
    $600 Craigslist bean
    Rarely Go Off-Road
    Oregon
juno1228's Achievements
  1. AFAIK it should be any year XJ model 1984-2000 (?). I know they had a facelift in the 90’s but I don’t think that changed the suspension at all. Also, do you need to mod the XJ springs to fit like you do with Grand Cherokee stock springs? I know JGC spring swaps are common for budget lifts and I remember people talking about bending or doing something to one side to match the Nissan springs?
  2. My '95 has a totally worn auto trans. I've decided on swapping in a manual. I am looking at a cheap 1997 R50 with the VG33 as a donor for the trans (and later the motor, but it knocks rn so rebuild first), are the other parts I would need (clutch pedal/pedalbox, clutch master cylinder, etc.) in the newer model or would I need to pull them from a WD21?
  3. My '95 has a completely worn auto trans, I want to swap in a manual. I'm looking at a cheap '97 pathfinder to swap in its trans (and later engine, but it needs rebuilt). Are some other parts like clutch master cylinder, clutch pedal, etc. that I would need to do the rest of the manual swap in the newer model? Are there any other important steps or things I need to know about doing a manual swap?
  4. My '95 has a completely worn auto trans, I want to swap in a manual. I'm looking at a cheap '97 pathfinder to swap in its trans (and later engine, but it needs rebuilt). Are some other parts like clutch master cylinder, clutch pedal, etc. that I would need to do the rest of the manual swap in the newer model? Are there any other important steps or things I need to know about doing a manual swap?
  5. My '95 has a completely worn auto trans, I want to swap in a manual. I'm looking at a cheap '97 pathfinder to swap in its trans (and later engine, but it needs rebuilt). Are some other parts like clutch master cylinder, clutch pedal, etc. that I would need to do the rest of the manual swap in the newer model? Are there any other important steps or things I need to know about doing a manual swap?
  6. Hey! Do you know if I should install a new transfercase too? Or will the current one on my Pathfinder still work?
  7. What years are the first gen Xterras and Frontiers? Do they need to be 4wd? I'm only wondering about the 300zx because I found a sort of cheap one used. Thanks
  8. Will an auto trans from a non-turbo 1992 300zx fit in my '95 SE-V6 pathfinder? I see they use the same trans model but I'm not sure if the transfer case will fit? thanks in advance
