awildbabyshark
Everything posted by awildbabyshark
  1. Hi, So I've been looking and looking for a suitable way to replace the links with something a bit easier to replace in the future. I've come up with 2 options, 1 is to replace with fuses of the same amps or 5 amps higher than the fusible link is rated. 2 keep fusible links but instead of a plastic connector make something where they connect with eyelet terminals to pop off and on when in a "side of road" or "off road" situation. Either way I need to know the amp rating of the fusible links, or at least the awg of the links. After searching online I've found a chart for Nissan fusible links that says Pink-30 amps Green-40 amps Red-50 amps Yellow-60 amps Black-80 amps Yellow-100 amps After more research I find an amperage rating chart for awg of wires, which I won't write because it's long and easy to find. So after cross referencing it seems that the green wire at 40 amps makes it a 12 gauge wire. Which it clearly is not big enough. I'm guessing it's a 16 gauge. But that's just it, I do not want to guess. I want not just me but all of us pathy lovers to be able to buy spools of fusible link and make spare links we can toss in quickly and easily, or fuses, of proper ratings. For that we must know the amperage or gauge of the black, green and pink wires please and thank you.
