robins94
    1999.5 SE
    Ontario
    Canada
robins94's Achievements
  1. Ive got a 1992 imported rhd Terrano with the td27t with 220,000km and new 5 speed manual with maybe 5000km, the body and frame is pretty rotten. I picked up a high mileage 95 pathfinder that spent most of its life in colorado. its mostly rust free but has 430,000km on the original vg30, id like to swap the TD27T motor and manual trans into my us spec 95 pathfinder. Is there any TD27T swapped pathfinders on here ? My concerns are around fitment with turbo and downpipe going from rhd to lhd, what would need replaced with the fuel system, i assume i could swap the ignition switch to accommodate the glow plugs or run a manual timed switch, would i need to swap the axles over to for gear ratio?
  2. So I got fog lights from a scrap yard and installed them with the pre installed factory wiring, I realized I didn't have the switch on my turn signal handle so I am unable to use them. I am wondering if there is wiring under the dash that I could wire a on/off switch to instead of buying another turn signal handle with the fog light switch. Has anyone had this issue ?
