Evan3029
    1987 Nissan Pathfinder 3.0 V6 SE
    Washington
Evan3029's Achievements
  1. Hello! I recently changed the fuel injectors in the throttle body as well as the fuel pump and filter because the vehicle was sputtering during acceleration. I found that after doing that, the engine still bogged down during acceleration so I checked the ecu for any codes and it threw a coolant temperature sensor code. I changed the sensor and now whenever I start the truck, it runs decently for about 20 seconds and then begins to surge while idling. Any tips on what I should do? Thanks
  2. Hello! I recently changed the fuel injectors in the throttle body as well as the fuel pump and filter because the vehicle was sputtering during acceleration. I found that after doing that, the engine still bogged down during acceleration so I checked the ecu for any codes and it threw a coolant temperature sensor code. I changed the sensor and now whenever I start the truck, it runs decently for about 20 seconds and then begins to surge while idling. Any tips on what I should do? Thanks
