duston
    1990 SE
    Screwdriver Mechanic
    Washington
duston's Achievements
  1. Every time I run the codes it gives me 55 except for about an hour ago I tried it and it gave me a code 11 one time and then when I looked for the code again it wouldn't throw that code but that code is a crank position sensor which is in the distributor I believe which is about where I'm losing my spark I got spark from the coil to the distributor
  2. No spark, cleaned all my plugs one was broke in half, I replaced it. Still no spark
  3. I rebuilt the starter got it in today it works fine turns over cranks but won't start
  4. So the starter went out a few weeks ago I've been pop starting it up until the other day when it decided to die on me with the morning and now it won't start I have since rebuilt my starter it now works but when I turn my key it just makes a weird spinning noise and it's not turning the engine and the interlock button when I turn it doesn't illuminate on the dash
  5. So I started to find the other day enjoy it for about 15-20 minutes and then it just cut out completely has battery it has gas but it won't start back up it gets fuel past the fuel filter the interlock switch no longer lights up on the dash when I try to use it to start it I'm wondering if that's part of the issue.
