Jacko
    2005 r51 pathfinder
    Screwdriver Mechanic
    Other/Unknown
    Brisbane
    Australia
Jacko's Achievements
  1. I found where it is turns out it is the fuse for the ignition circuit, which means that there is a cut wire somewhere.
  2. I think i have found the issue anyone know where the 40Amp fuse with the J below it is located
  3. ive checked all the wiring to the witches everything that is supposed to have continuity does apart from the illumination wire but that has been fixed after repairing the wiring to the headunit
  4. thanks I'm pretty sure the us and aus model were the same idk if the us got the yd25 model though but I've pretty much gone through the whole wiring harness and repaired it all from the damage, it was really messed with when the last owner did a head unit install but that seems to be all fixed from my knowledge and what i can see in the haynes service manual.
  5. I recently bought an 05 pathfinder from auction for cheap, everything on it works great apart from the fact that the four wheel drive wont switch, no light on dash no noise from transfer case motor and the relay wont do anything, please help if you know anything.
