Capt.SK
Everything posted by Capt.SK
  1. Thank you very much Slartibartfast. So the crank position sensor does not actually detect crank position at all? but rather engine speed hmm. If that is the case it needs to be renamed. I am 55 with arthritis and cancer treatments . it was really hard for me to remove the transmission. I tried to download the clutch section and I could not find torque specs for the flywheel or pressure plate. The closest I can find from other sources is 70ftlbs flywheel and 30ftlbs for the pressure plate. Thanks again.
  2. Hi, New member, and longtime lurker. I am in the midst of rear main seal, clutch, and oil pan R&R. It is all going back together now. I removed the flywheel to replace the rear main and I had it resurfaced. Since this engine has a crank position sensor that reads the flywheel it would make sense to me that the flywheel would be indexed to the crank. There is no dowel on the flywheel or a place for it. there is also no arrow or timing mark that I can see. There is an extra hole next to the bolt holes on the crank but nothing corresponding on the flywheel. I should have marked it when I removed it but I wasn't thinking about it. I need to have this correct if it needs to be indexed. I have looked hard and I can't find any information on this. Please help. Thank you, Capt.SK
