joeyd50
Everything posted by joeyd50
  1. I'm looking for the coolant temp. sensor for a 1994 Nissan P/U, 3.0 V6, 4X4, Auto trans. I was told there are two of them, I'm looking for the location of the one that reports to my Computer. Thanks Joe
  2. joeyd50
    Codes
    I check the ECU and came up a code 55 witch means no malfunctions. Checking the code I would turn the key on, then turn screw fully clockwise, wait and the red and green light would blink 2 times and then it would blink 3 times, at that point I turn the screw fully counter clockwise. Then I got 5 red flashes and 5 green. Did I do this correctly? Thanks Joe
  3. joeyd50
    Codes
    Yea, maybe 3 seconds, it starts fine RPM go up to around 1800 and then it just dies. I took the fuel filter off and ran a piece of pipe so there was no restriction. Once it warms up it runs fine. Thanks Joe
  4. joeyd50
    Codes
    Just for the hell of it I just went to check the fuel cap to see if it was on tight, and soon as I opened it all kind of pressure released. To me it seens like the chokes not working, or what ever it has instead of a choke.
  5. joeyd50
    Codes
    I'm having trouble with my 1994 Nissan starting, it starts fine, idles up for a second or 2 then dies,after that I have to keep my foot on the gas to keep it running, 3.0 4X4 auto trans. There's no check engine lite lit, could there still be a code that would tell me ups with this. Or what do you guys think it is? Thanks Joe
  6. joeyd50
    idling ?
    Been gone a while, lost the site,1994 4X4 3.0 V6 Automatic, 358000 miles, Truck runs great once it worms up, when I first start truck in the mourning now it wont idle, I got to keep giving it gas, was starting and idling fine up to a few days ago. Where should I start looking first? Thanks Joe
  7. Thanks guys, I saved the website, thats some scary $hit that ref. and oil in eyes. Do you know how to recover the system? I see bad enough now as it is. Thanks Joe
  8. I switch to Comcast and had the hardest time finding this site. I have a 1994 P/U XE V6 3.0 4X4 I need to know if I need any special tools to remove the A/C clutch? I'm replacing the A/C clutch bearing, I also like to know if this bearing is pressed in? Thanks Joe
  9. I sure can use a little help, 1994 Nissan P/U 4WD XEV6, I just put r/brakes on this thing and can't get any type of brake spoon in to adjust these brakes, is there a special tool or something you gays made to adjust theses brakes? Thanks Joe
  10. I really should know this, I have a 1994 Nissan P/U 4X4 with 3.0 motor, what should the spark plug gap be? The guy at Auto Zone said .032 when I took the plugs out they were a lot bigger then .032, I called them back and they said .032 What should the gap be? Thanks Joe
  11. I have a 1994 Nissan 4X4 pick up automatic with the 3.0 motor, the problem is when I go to start my truck, I turn the key, hear a click and I hold the key in the start position and in about 2 to 4 seconds the truck will crank and start. The 2 to 4 seconds I'm holding the key nothing happens and then all of a sudden she'll start cranking and start right up. Any ideas what's causing this? Thanks Joe
