ruggs
Everything posted by ruggs
I am looking a buying a 88 Pathfinder. The thing has been sitting for about 5 years. It starts and idles fine, but as you drive down the road it'll die on you. That's all the info i have on the subject but I wanted to know if you guys had an idea on what it could be. Thanks for looking
Never mind, I guess it is 3.3L!! Iam going to put in around 3.75 L Cheers
I don't have a manual for this truck. It's an 87 withe vg30 v6 and I need to know the oil capacity in liters if possible, if not quarts. I ahev heard that they only tak 3.5 quarts but that seems really low. That's like 3.3L !!!
Its fixed!!!! It's never runs this good. Thanks Matterhorm and company for the info. It was a combination of a bad wire, 2 vacuum leaks and and the fast idle being way out of adjustment. The previous owner must have totally focked with it. Cheers guys, now I don;t want to sell it
I will check for that vacuum-t and I am about to put the new wires on. I'll keep ya posted. That vacuum leak would make my idle lumpy adnd make the puffing chugging sound though would it?
I am going to get another set of wires to see if that helps. I should also check the plugs while iam in there just to make sure they are fooked. I never looked at them in the 5 months since I've owned the truck. By the way, now that my truck idles at 1000 rpms at warm, the oil pressure gauge reads 0!!!!! That's not a good thing. And that's with 20w50 in there!!! I also found a cut vacuum line coming from what looks to be my cruise control. What is it supposed to be hooked up tp and where? I have a feeling there may be a vaccuum leak somewhere because of that but I haven't found it yet.
OK, I adjusted the fast idle cam, it was way out of adjustment if your info is correct and I'm sure it is. So now my truck runs at 1000 rpm at idle when warm which is better than 1500 like it was, but it is still puffing and idling lumpy. WTF could that be? I can't see it being the idle being out of adjustment that is making my motor sound like it has a burnt valve...... When I was manually operating the throttle with my hands I got a mjor shock from the motor. My hand was against the dist. cap but it shouldn't shock me like that should it? Unless I have a bad wire? the cap is new. Could this be causing that puffing sound ie. a dead cylinder at idle but enough juice to fire the cylinder at higher rpms? Please help me!!! Timing is set at 14 degrees instead of 12 degrees because it ran better before at that setting. I'm sure 2 degrees would be causing this problem either.
i will try all that. Thanks for the info. Here's another question while I am here.... When I take my airfilter out and close up the aircleaner assembly say to pass aircare, my motor idles really low and wants to stall. That doesn;t seem normal to me at all since I have done that to other vehicles to put them thru aircare. Maybe this another indication of a problem. I just thought I'd mention it. cheers
What does the thermo element look like? What does the fast idle throttle cam look like. I haven;t messed around with Nissan tbi's at all so I need all the help I can get. I will take a look though. Another question though, if I had a bad plug would it be posssible for it to still fire at higher rpms but not at idle? I am starting to think I may have a burnt valve becuase of the rough idle and puffing sound coming out of the exhaust at idle. Keep the info coming guys, I appreciate it
@!*%e!! Could the fact that I didn't reset the ecu make it not realize that there is another distributor in there?? if that's true, that pisse me off!! can anybody vouch for that idea? If so maybe I'll try that dist. again. I will also check that wax choke. Also, I think I may have a burnt valve. At idle it's really lumpy and produces a sort of puffing sound out the exhaust. When I am driving thoug it seems fine...............WHO KNOWS!!!!!!!!!
No , I can't see it being any of those being the problem. The truck has done this since I bought it. Plugs, wires, rotor etc, would not create these problems. I have plenty of vacuum so I don;t think it's a vacuum leak thing. Like I said, it seems like it is missing at idle but not under load when I am driving it. There has got to be someone in this forum that has an idea............ :sniff:
Hi I have an 87 Pathy w/ V6. Here is my problem.... WHen I start it up when cold it bogs for a second then idles at 2000 rpm, then it will start dropping to 1100 and then back up to 2000rpm almost like the egine dies then pickups up again. Once it warms up it stays to around 1500 rpm and it idles lumpy and kind of makes a sputtering noise out of the exhaust. But when i hit the gas and when I am driving it feels fine and doesn't miss or anything. WTF is the problem with this POS? I checked the computer and it said CAS is toast but I swapped in another distributor and it did the same thing!!! SO I think it was an old code or something. THe engine light was never on. Any ideas ???
Thanks for the info guys I figured it all out, but when I put the used distributor in I found that the truck still runs the same so the CAS in that dist. must be screwed too! What a pain in the hiney!!
I just got a distributor for my pathy (87) but I forgot to mark where the rotor position was ans now my pathy won't start. How do I find TDC on this motor and then what irection should the rotor be in. I need to get this thing running now!!! or I am FOOKED!!! :furious:
Shocked when adjusting timing... wires shorting?
ruggs replied to ruggs's topic in 86.5-89 WD21 Pathfinders
I just replaced the old dist. cap. It not only had a hole in it but it also had rusty and oxidized terminals inside. But get this. It still runs the f'ing same -thnkboutit- I know the crank angle sensor is shot in my distributor so maybe that is causing all the problems but I still figured with a cap that messed up that it would run better. F ME!!! The wrekers want $150 for a used one and a rebuilt one costs $300. And I still not sure if that's the problem. My dad says that I may have a burnt valve. Does anyone know what that would sound like or what the symptoms would be? -
would that cause missing at idle if the cap had a hole in it? I would think so.... -
Ya , ia m going to do the old spray water over the motor in the dark to see if there are any sparks. That should show me what's up. But regardless, it shouldn't shock me like that so there must be some arching going on. -
I meant shocked not shriked -thnkboutit- -
My truck seems to be missing when idling but not when under load. I was told it was the distributor but now im not so sure. When I was adjusting the timing, with it running obviously, I had my hand on the dist. cap and was turning it to advance it a bit and I got a huge hiney shock from it. I have done the timing on many vehicles and this has only happened to me when there was a short. So what do you guys think? Do you think its a bad wire that's causing me all this grief. I just want another opinion before I go and buy a set of wires. Cheers Ryan
ya , I think I'll put in some thinner synthetic oil soon. Thanks for the info
Hey guys I just did an oil change inj my 87 pathy and I put in 20w50 oil in there cause I thought the old motor would like the thicker oil, but now at start up it does a load ticking noise now and it never did that before. Is that because the oil is too think to get up to teh top end fast enough? Sounds like lifters to me. Should I go back to the 10w40? BTW, I live in Vancouver, bc for an idea of what teh climate is like. Also what should my oil pressure read ofter the truck is warmed up? On my gauge it reads around 2-3 kpa. Ryan
change that into CDN $'s and I am fawked !!! Thanks for the info. What other cars have the some engine? What year maximas are interchangeable. So uyou replaced the distributor in yours and it still does it? Does that mean that teh replacement is toast too?
no friggin way.......... I have to replace the distributor!!! How much cake is that gonna cost me? Would that sensor make the symptoms I have described above? ALso does the distubutor out of the newer efi VG30's match the one in mine with the throttle body injection? After I reset the computer the first time, the code 11 didn;t come back, just the unknown 44. DOes that mean that the problem isn;t there anymore or dis I just erase it? Thanks for all the help man
11 Crank Angle Sensor/Camshaft Position Sensor. That is the exact error code that I have got flahing on my ecu. That and 44? Any ideas anybody?
Ok so I finally got around to do the diagnostic test on my pthfinder. The first code that flashed was 11. The crank position sensor. WTF does this sensor do, is it expensive and will it cause any drivability problems? Has anyone had this code before? So then I erased that code to see if another one would come up and 44 came up. But there is no 44 code, atleast not on the code list from this website. Anyone have an idea of what that could be? :confused:
