Hello all!
I am in the middle of a front end refresh (CV axles, repack bearings/replace seals, rotors, pads, TRE, ball joints, sway bar bushings) and have hit a snag:
When I peeled off my passenger side CV axle, I saw what I believe to be some nasty gear oil leaking out of the flange of the differential side shaft. I have a couple of questions regarding this discovery:
- how could gear oil make it to the flange of the side shaft (where the CV axle mates) as the seals are inboard on the extension tube (this is the side opposite the pumpkin)?
-is this just CV axle grease that has leaked out of the blown CV axle? smells a bit like gear oil however... but that could have been my gloves, that smell sticks around forever. The bottom of the extension tube doesn't appear to have a leak, just tons of old grease from the blown CV boots.
-if I want to replace the grease and oil seals in the extension tube, can I remove the whole side shaft assembly from the extension tube by removing the four bolts on the extension tube retainer and pulling the shaft out, no need to mess with the internals of the diff. I don't see a retaining clip in there on the FSM diagram like is common on rear differentials to keep the shaft in place.
The FSM for the R200A front axle (what I believe to have, 94 SE 4x4, MT, HG43 axle code in door jamb) has a single frame of a diagram showing a hammer tapping the side shaft assembly but is short on instructions. Attached is a frame of the manual showing the assembly I'm talking about. Thanks in advance.
siggy
