ride4thrill
Everything posted by ride4thrill
  1. Thanks for the help I ran the codes and came back fine. I want to try the Temperature Sensor I went to the auto store and 3 came up Ambient Air Temperature Sensor Coolant Temperature Sensor Ignition Air Cleaner Temperature Sensor Wich one could it be? I want to say the coolant one because it is the cheapest. Please help one more time.
  2. hi I have a 87 pathy, 3.0.. I have been having some problems with the RPM. When the truck is idleling my RPM goge from 1000 to 100 ant back up on its own. It almost dies on me. this is what i have done to it New Plugs and wire set. Check pump and pump presure. New fuel filter. new distributor cap (not the roter.) Please help its killing my gas.
  3. My bad pleaced the wrong comment to your problem it was the distributor cap. I got it at Autozone for $20 dollars. Sorry once again. Before you buy a new one take it of and get some sand paper and clean it from the inside. If it improves a bit get a new one.
  4. I had the same problem and did everything that you have done if not even more. This is what finally fixed the problem. I cleaned the idle air control motor (valve). It was clogged up. Here is a link on how to clean it. http://www.crossfire.homeip.net/tech/iac.pdf http://www.autoshop101.com/forms/h60.pdf
