G'day,
I purchased a 2000 R50 Pathfinder recently with the electric transfer case. It appears as if the transfer case is stuck in constant 4x4H mode. I've run the diagnostic that is built into the system and no faults log, I can select all of the modes and the system believes it is engaging by just a single beep. I can switch between 4H and 4L fine, but I cannot seem to get the wet clutch pack to disengage and go into 2wd mode.
I've done all manner of forwards and reverse, full lock to full lock on and off tarmac and nothing works. I've changed the fluid in the transfer case, the stuff that came out did not have any chunks in it and didnt look too bad.
Considering no faults are indicated and everything appears to switch with no issue, a friend suggested the clutch pack itself may be stuck together. Has anyone experienced this before? Are there any additives I could try and add to the transfer case to try free them up?
cheers,
Nik
