2000 LE, PEARL WHITE. 24X10 BSA WHEELS W/ 275/30/24 TIRES.
36-40
Do Not Go Off-Road
2000
Gender
COLLINSVILLE, VA
kidrock's Achievements
Thanks. It's got be be something like that because I have followed all the steps listed above. I just hate to take all that s#*h apart. I've found out if it says "simple" or "easy" look out.
Hey guys, I'm trying to replace my antenna. OK, all the instructions I have read says; just take the base nut off. Turn the key on, and pull the mast and the cable out. For some reason mine will not come out. It's like something is holding it that I can't see. Any ideas? Thanks.
Not big tires. Bigger wheels. 30" wheels with 315/30/30 tires which = 37".
Now if you take the flaires, running board, and trim the front fender some more, I think they will fit.
Yea, they cut my MPG to about 11. But I guess its about the same w/ mudders. I only need 2" on each side of the front and back wheels. It looks like if I take the flairs off and trim the front fender some more they will fit. The only concern I have is the fender well behind the front wheels.
Says to many Obytes.
How do you post a pic on this site? I've tried everything.
Has anyone ever tried to put a 36" or 37" tires on a Pathfinder? I've got 33" inch tires now w/ AC lift. I still have a 1" spacer to put on the front. I already have plenty of room now. I trim my front fender and can cut about 4" more. I've also cut the metal body work in the front fender well. If I take the flairs off and the side rails and put the spacer in, would they fit?
I will let you know after we call. Hey the calls expensive, too!!!!!
I can't go any bigger or I would. My tires stick out about 1.5", and I want a flair to cover that.Yes, I know they are Asia. Japan exactly. Good thing my wife is Japanese. We are calling the guy that sells them tonite. I just though someone made some over here. You can't find ANYTHING for a 2000 Pathfinder. And they are not that expense. $38.00 a flair + shipping. The shipping is the killer.
Does anyone know where you can get large fender flairs(3")? Picture attached.
I'm excited!~ I've been waiting for these for about 2 months.
