oldmantox
    1995 Nissan terrano/pathfinder
    Terrano R3m
    new zealand
    New Zealand
oldmantox's Achievements
  1. its making the noise when driving straight then when i went to turn around was getting a lot of resistance turns and runs fine when in 2wd
  2. i'm getting a noise from what sounds like the front right hub only when in 4wd thought it might be the auto hubs, so swapped them out for some manual ones but still getting the same noise, have also replaced wheel bearings. Hubs are engaging and disengaging ok . When i put into 4wd drives fine for awhile then the noise appears, if you try and do a hard right hand turn it seems lock up. could it be the cv or spider joint is no good??? thanks for any info in advance OLDMANTOX
