RanoNZ
    1991 WD21 Nissan Terrano TD27 turbo diesel manual
    Terrano R3m
    New Zealand
    New Zealand
RanoNZ's Achievements
  1. Yea hydraulics are fine, I just had the clutch removed again and another brand new Exedy installed and its still exactly the same, current suspected problem is excessive crankshaft end float. Yea motor runs fine as well. Thanks for your comment though 😊
  2. Hi everyone Im new here, Needing help with my Terrano, it has bad clutch shudder in 1st and reverse while slipping clutch. It is literally just out of the workshop where its just had gearbox rebuilt and a brand new genuine clutch kit installed along with a professionaly resurfaced flywheel. Also had rear main seal done and new throw out bearing and spigot bush. So it's previous clutch had exactly the same problem, and the new clutch has done it right from the get go. Engine and gearbox mounts seem ok, only problem I can find is that the clutch slave cylinder boot is full of fluid, but it still seems smooth and perfectly operating. So yea the mechanic thinks its a faulty clutch plate, but I would love to hear if anyone here has had a similar problem. Thanks in advance Cheers
