Long time reader, first time poster...
I have been upgrading my R50 (by necessity and by desire to make it more offload ready) and have come across an issue that I can't figure out. I had a steering rack leak and ran out of fluid to the point of squeezing / whining a couple of times. I replaced the rack and the rack and it no longer leaks, but the pump groans when under load - i.e., not moving and cranking the wheel or at the far ends of tight turns. In addition to the steering rack I have replaced all suspension, control arms, tie rod ends, strut mounts, ball joints, etc. - but not all at once. All along I have had a shimmy I could feel at the steering wheel and kept thinking "oh, this is going to fix that" as I upgraded and replaced things, but still have a shimmy that is not consistent. I even replaced the power steering belt thinking it was worn or glazed, this solved the issue for a few days, but the shimmy is back. Is it possible that the pump was damaged and now causes a "surging" in pressure that can be felt at the wheel?? I guess I think of a bad pump as a leaky pump, but it does not leak. Tires have been balanced twice, alignment is good and tracks fine, but the shimmy comes and goes to varying degrees and the pump still groans under load or when hot. My vehicle has really come to life and drives great with with exception - THE SHIMMY!!
