Jake0317
    95 - 3.0 - white - 4x4 - 5 speed manual - 210k miles
    Rarely Go Off-Road
    XE
    Camp Lejeune NC
1,016 profile views
Jake0317's Achievements
  1. Thank you for the ideas! I'm am currently still searching for the issue.
  2. Clutch interlock switch doesn't really make since because nothing in the dash works or the fan even when the truck is running and yes I did
  3. Okay so here we go. 95 Pathy. 3.0 , 5 speed manual Will not start. When you put the key in the ignition and turn it once, the radio turns on like normal. when you turn it to the next slot nothing happens. Obviously what should happen is you dash warning lights turn on and you gages begin to work and your fan should work. Nothing works. Then you go to turn it over and you can here the Ignition relay click but that is all that happens. You can push start the pathy and it runs and is drivable, however the problem is still there. No gages, no dash warning lights, no fan or A/C. So I checked all the fuses and replaced some that were good but where dirty from age. I replaced the ignition relay even though it was good. I bought a new ignition assembly, plugged it in and tried it. Everything remained the same. I replace the battery connections and the battery itself. I have been asking around and no one seems to have a clue what it could be. I could really use a hand here if anyone has any insight into what the issue could be. Also just incase there are any locals on here. I am a Marine stationed on Camp Lejeune, N.C. I appreciate any help that is offered. Semper Fi
