**FIRST TIME POSTING -- SO BE GENTLE!**
(And I apologize on the front end here if starting this new top breaches any rules or covers any ground that's already been covered... couldn't find anything on this)
I have a 2003 SE that has two things going on I don't know how to troubleshoot.
1) The heat/ac fan works only intermittently for no apparent reason. It will all of a sudden kick in, I can adjust up or down in terms of fan settings and then it will go for a period of time and stop. Sometimes comes back on, sometimes not. Sometimes won't work at all for a drive or two. Is there anything that may be simple that I can look into? I have the middle dash area removed so the unit is accessible.
2) My Bose 6-disc Changer/Cassette/Radio stopped working. Just 'went out' about a year or so ago. Removed it to see if anything seemed loose in back and it simply wouldn't come back on. So I thought I was going to simply get something aftermarket but like having OEM equipment. Today I went to give it a try, plugged it all in and it worked! It was awesome.... And it was only for about a minute and the power went away. Unplugged everything again a retried and it worked again!... For about a minute. Now it doesn't matter if I reconnect everything... it's not powering up. SO! Like my aforementioned fan situation... is there anything that is simple enough to look into? Like figuring out if it's the wiring, the radio unit itself or something else? I believe I've looked at all the pertinent fuses.
Any help would be appreciated.
Thanks in advance!
