digimaus
About digimaus
  • Birthday 08/27/1972
    1995 Pathfinder XE 4WD, over 220,000 miles and still going!
    XE
    Limestone, TN, USA
810 profile views
digimaus's Achievements
  1. Thank you for the advice! My Pathfinder has an automatic transmission. I'd not thought about the ignition switch on the back of the ignition lock. Is there a good place to get something like that you'd recommend? As for the starter, I bought a new Bosch starter, not a reman. I paid a bit more for it but that was worth it. I bought it at Rock Auto and the starter itself is working fine from what testing I've done (albeit limited testing). This was the -third- starter I put in it. The other two were remans from local parts stores that turned out to be DOA. Thanks again! I really appreciate it.
  2. Hello everyone, I'm trying to diagnose an odd issue with my 95 Pathfinder XE 4x4. It's sat for several years but now with my being unable to work due to a health issue and the necessity of having a vehicle, I'm trying to get my Pathy reliable again. What it's doing is this: when starting, the starter will spin just fine then suddenly starts to barely move, acting like it's starving for current. Eventually, the Pathfinder will start. But if I drive it until it gets hot, the engine will refuse to turn over, usually just giving me clicks of the starter relay, for at least 30 minutes (longer if it's really hot out). The battery is also being drained after about a week of sitting. The engine itself runs decent though it has some issues I will cover in another post eventually. Once the vehicle starts, it is drivable. I have replaced the battery, starter, and alternator ... and about $5000 worth of other parts on the vehicle, maybe more. I'm now in so deep with my Pathy that trying to get rid of it doesn't make sense ... besides, once it starts, besides needing the anti-knock sensor replaced, it will drive and the 4WD system works just fine. So I am trying to figure out where to start. I did go back several pages worth of posts in this forum and I'm suspecting the distributor may be bad and the fusible links may be shot also. The distributor is easy enough for me to figure out but how do I go about replacing the fusible links? Once I am able to work again, I'd like to get the Pathfinder going ... I've replaced a LOT of parts on it like the water pump, timing belt, the front CV axles, a transmission rebuild, new tires, new shocks, new battery, new master cylinder, new starter, new alternator, new belts, new A/C system, new heater core, new heater fan ... so it behooves me to get the Pathfinder running again. Any help is appreciated. dm (Sean)
