93pathfinder
    1993SEV6
    Canada
    Canada
93pathfinder's Achievements
  1. Thank you all for your suggestions, I will definitely look into it. But as of now the front speakers are working just fine again. When they stop again I will start taking things apart. Sent from my E6560T using Tapatalk
  2. Hey fellow pathfinder owners. I have just recently purchased a 1993 SE. My problem is is that my four front speakers just stopped working. The deck is an older Alpine unit. The speakers were working fine just the other day and now there is no sound from the front. The rears work fine. I checked the fade on the stereo and it was right in the middle and when all the way to the front there was no sound. Just wondering if this might be a Pathfinder specific thing, considering that the Alpine wouldn't have an 8 speaker wiring harness. Thanks Sent from my E6560T using Tapatalk
  3. Well for pathy up to 95 you can use f250 2wd rear shocks on the rear, stock size of course. Years would be 95 f250. For the front you can use 88 Bronco 2 front shocks. Some minor modification is needed to make them fit. You have to drill out the bushings on the rear shocks and I believe the stem on the front shock is a little larger than ours so that has to be addressed. Sent from my E6560T using Tapatalk
  4. Thanks cntryboy_88, I appreciate it. I thought that was the case but just wanted to check. Going to order everything now, thanks.
  5. Thanks for that, but it doesn't say if they are f250 4x4 or 4x2 shocks. I was just going to buy some cheepies. But thanks again
  6. First hello everyone I am.new to this forum. I am wanting to lift my pathfinder and have done some searches on it and got most of the info I need. What I have not gotten is the rear shocks for the lift. I know guys are using rear f250 shocks, but which ones? 4x2 or 4x4 shocks? Also I know that people are using the JGC coils and that the upcountry gives more lift, the one thing nobody has mentioned when they talk about this is whether or not they are using a drop track bar bracket with this set up. Would love to get that last bit of info before I start ordering parts or you g to the wrecker. Thanks for your help.
