Jairo2000
Everything posted by Jairo2000
Hey, guys I just want to know if you could help me resolve this issue, I've been having recently. Two days ago my "ABS" light turned on, while I was driving, then when I got home I turned the engine off, then on again. The "ABS" light was gone, but the brake lights remained on. Even when I wasn't stepping on the brakes, so I just pulled out the fuse so it won't drain my battery. can it possibly be the brake light switch? Any suggestions would be helpful. Thanks in advance 1995 Nissan Pathfinder XE
Is it possible that my power steering pump is failing? Is the correct name of the part called "pressure sensor"? I can't seem to find that part that's why. Thanks
Hi, the rpm does not rise in a standstill. The rpm is stable throughout.
Hey, guys I own a 95 Nissan Pathfinder XE. Recently I haven't been using it for 4 days, when I used it today the steering wheel felt tight (kind of hard time turning) everytime I turn it to the left or right. It only happens at slow speeds though. The last time I used it, it was fine. Power-steering fluid is not low. No leaks that I'm aware of. You guys have any insight on what the problen might be? I mean it wasn't like that the last time I used it. Which was 4 days ago. Thanks for the help.
Hey, guys just an update the problem on my 95 Nissan Pathfinder XE, was the distributor. Replaced it everything runs smoothly. Thanks for all the help.
Hi, guys does anybody know how I can disable the factory car alarm? Since it might be causing my pathfinder to just crank & not start. If I disable this & that is the problem will my pathfinder start right up? I've been having issues with my alarm. Thanks all for the help. This forum has helped alot.
Hey, blue24hike I think I may have a similar problem like yours. How did you go about disabling your alarm system? I have the factory alarm installed. Is it possible that you could help me out, on how you disabled your alarm. Thanks
Hi, yes I do have funky alarm issue. The factory alarm has been acting up, it tends to alarm on it's own at times. Is there any way I can go about fixing this?
Hey,guys I've been trying to figure out this problem I've been having with my 95 Pathfinder XE. After like 5-10 mins of idling the engine just dies & cranks, then waiting for a while it will start right back up again. I've cleaned MAF sensor, changed the ignition coil, Main Relay & Fuel Pump Relay both click, changed the ignition control module (power transistor) & cleaned the distributor cap & rotor. I even checked the ECU & got a 55. I checked for spark & it seems like when the engine dies, & I crank it there isn't any spark coming from the ignition coil to the distributor, but after waiting a while & letting the car rest & starting it again there is spark. Really don't know where the problem is coming from. Any help would be appreciated. Thanks.
Hi, will you guys be so kind to assist me on where the ignition control module (IGM) is located at? Thanks so much
Hey,guys I was wondering if any of you know where I can get a efi main relay? for a 95 nissan pathfinder. I've asked in several auto parts store & they said they don't care it. Thank You
Hi guys, I'm new at the forum. I was wondering if any of you guys can help me out, well recently my pathfinder 95 has been dieing out after 5-10 mins of idle. Then when I try to start it, all it does is just cranks after waiting for like a minute or so, it starts up fine. Can this possibly be the fuel pump? Or fuel pump relay? I did a self-diagnostic & got a 55. How does the fuel pump sound like when starting up? I really don't know what the problem is. Any help is much greatly appreciated. Thanks in advance
