georgi.m860
    Canada
georgi.m860's Achievements
  1. Hey so I just installed a 24 inch led bar and I found that if you have an automatic r50 hands down the easiest way is through the clutch plate. I took off the clutch plate and behind it was a gap with a small metal plate across it. There was enough space for me to feed 3 wires in for a switch and the location for the button works out perfectly. I had to cut out a tiny corner from the clutch plate and tape it down so it wouldnt cut my wires. Taking the two 12 mm blots off feeding the wire and cutting the plate and putting it back together took under 8 minutes. Enjoy! ( ps this firewall break is as far from the battery as possible. The universal harness I was using did not reach the battery terminal so I had to splice in 3 feet or so. That's way easier than fighting through wiring grommets and air vents or whatever other firewall option out there.) Sent from my SM-G920W8 using Tapatalk
