shogunb
Everything posted by shogunb
  1. Do you still have the R50? Did you do the sub frame drop? And How close to olympia are you.
    I'm putting in a TDI ALH 1.9 into the pathfinder. I drive 2001 as my daily and have 96/97 pathfinder which the diesel is going into. I have an oil pan which I call the $7000 oil pan, as I have been really slack in trying to get my aluminum tig welding to point which is useful, so that I can modify the oil pan to work with the stock subframe height.
    Somehow, I came across the subframe drop yesterday, if I do the subframe I will get sump clearance between the diff. At the moment in theory, I have lost half the capacity of oil pan.
    Also previously owned a red 1995 Nissan D21 Pathfinder and a WD21 TD27T Terrano in New Zealand.
    Cheers
    Shogun
  2. Need help in identifying sound coming. I posted the video on youtube. Replaced Knock Sensor. Before that completely removed the right cylinder head to drill to fix broken exhuast studs in the head. Reclocked TDC for Crank off of No.1 cylinder and reset timing based on that. It Idles fine. Drives fine. No Errors Codes. I'm wondering if I burnt a valve up when I had a exhaust leak through the exhaust header gasket. Replaced Gasket today sound didn't leave. Maybe the mating surfaces aren't flat and exhaust gassing are getting by. Hopefully someone has a idea or two. Cheers Shogun
