Jables
Everything posted by Jables
  1. THANK YOU I've been looking for so long!
  2. What junkyard parts fit the 1999 Pathy? Or where can I get a legit lift kit for mine? I've done quite a few google searches and have come up with absolutely nothing.
  3. A LOOOONGG time ago I posted on here for my friend to hopefully get some answers as to why his Pathfinder runs like a turd. Well, taking everything that was said into consideration - we decided to opt for a new distributor. Now, we double checked how we installed this thing. It's flush and everything is meshing good. Other than we have a broken spark plug, there is nothing I can see wrong with this thing. The fuel pump works. New fuel filter. Oil change. New o2 sensor. New coolant temp sensor. But when you try to start it up, it would start up and die out. Now I can't even get it started again. I've tried putting it in neutral. Tried starting fluid. New battery. Charged the battery. Nothing I have done has made any difference. Any ideas?
  4. Okay, so first off, I didn't write an introduction because I'm just kinda on here for a friend who bought a 99 Pathfinder. I drive a Jeep, but he was looking into offroading with me and he didn't want to buy a Jeep. So he went out and found this beat up Pathfinder. It was throwing 2 codes to begin with, one code dealing with an o2 sensor and the other dealing with the mass airflow sensor. We've since then changed the o2 sensor and cleaned the mass airflow sensor and have removed the codes. The codes have not come back on and we've been driving it around quite a bit to see if anything throws out more codes. As of right now, it is not throwing any codes. When it starts cold, it runs perfect. No miss, no rough idle. Get it warmed up, and BLAM. Runs like a turd and stalls at stops. I've checked the grounds I can see, spark plugs are brand new, we threw in a new fuel filter and have ran seafoam through it. This is definitely not something I'm used to working on and nothing that has worked for me is working for my friend. Some people have suggested the coolant temp sensor is busted, but I'm pretty sure that would throw a code? Please help this poor soul. I want to see this thing run good, it's not a bad vehicle at all. Thanks in advance.
