boondox
    Screwdriver Mechanic
    Choose
    Choose
    Monmouth Illinois
boondox's Achievements
  1. Slowly it's coming along. I have all the heim joints and brackets. I still need to buy the tubing for it. Then just zip it altogether. Plus I got a new addition to the family Sent from my SM-G900R4 using Tapatalk
  2. To run 37's I'm suppose to use 5.5 tj front lift coils in the rear. To run 35's do I need to run the 4 inch coils. Also my rear upper coils r rusted out, so aftermarket coil mounts will be added.
  3. I agree the ratio for should be 5.57 for 35s and 5.86 for 37s. I'm going to run 5.38s on 35s. I have the factory 4.6 gears, if I had the 4.3 gear I would be where I needed to be. I'm going the cheapest route I can at the moment but still using as many parts I can from RR for the build.
  4. I would love to have the diamond axle, I just can't spend that much on a axle at this time. I have to spend what I can to get it ready by xtoberfest. I did splurge a little today though.
  5. I just picked up a set of axle for $300. A 1979 d44 hp and a Ford 9 wms 65 inch. The front axle has 1/2 inch thick axle tubes.
  6. It's only had 181k, just getting broke in.
  7. Thanx for the welcome. I won't replace the engine till it fails or locks up due to lack of snorkel options. After that I'll most likely run a 305 or 350.
  8. I'm trying to get back on the forums I got burned out on tnx postings.
  9. I can't delete the other post. Damn tap talk kept saying errors loading but it posted everytime I tried. DOH!
  10. I picked up the pathy for $800. I've been looking for a year now and finally one. Already bought the sas xmember from steevo at rugged rocks. I've already started the roof rack. I have a constant flow of parts coming in now. Just don't have much time to install and fabricate what I want at the moment. Roof rack started:
