crowy
Everything posted by crowy
  1. Hi Redpath.I connected the garden hose to the heater hoses at the engine not the firewall so hoses are good.(All hoses and radiator were replaced 14 months ago.Have the receipt from previous owner.I have had the vehicle about 4 months and other than the heater issue I love it.I replaced the auto hubs with manual locking hubs,now no more nasty engage disengage bangs Previous owner Also had Ironman shocks fitted just before I bought it I also had fitted a pair of 2 inch lift heavy duty King springs on the rear for when the trailer is loaded full of firewood,no more sagging!!Anyway back to the heater.I triede reversing the hoses at the firewall just as an experiment.A waste of 10 mins,made no difference. Here is a youtube video of a yerrano heater matrix.Not sure if it's a WD21 or not though.If it is all I can see is the heater valve on mine is closed(at least partially anyway) which is why the garden hose still pushed the water through. https://www.youtube.com/watch?v=o82tm9Ungmg Cheers Mate.
  2. After running the car to operating temp,inlet heater hose is hot.Return hose is cold.So coolant is not passing throught the heater core.but when I disconnect hoses and hook up a garden hose water passes through core.GRRR!!So there must be a valve on the heater box that opens and closes to let the coolant flow though.
  3. Heater core isn't blocked.The heater hose inlet next to the thermostat housing doesn't appeaer to have much flow.More like a trickle.Doesn't alter when switching from hot to cold on the sliding switch.Bothe heater hoses are near cold where they penetrate through the firewall.Seems like it may be an electrical fault There are 3 lots of wiring going to the housing that the thermostat attaches too.The wires going to the connection closest to the front of the vehicle sits right under the heater inlet.I'm wondering if this is just a sensor or some sort of electronic valve that opens and closes to let the water pass?Does anyone have an idea? :blink:
  4. Now I'm thinking blocked heater core? About to check it out
  5. Feeling the radiator hoses and comparing the temps compared to the heater hoses tells me there is no water flow through the heater box. Any Ideas?It's bloody cold here in winter!!! Thanks Redpath.Tested as much as I could.All controls on the heater A/C panel appear ok
  6. Wow !!Thanks for the quick response!!Ok.What I have found is if I put the Blower motor switch in the autu position and slide the temp switch acroo I can hear what sounds like a relay switching in and out .I dont hear anything like a door opening or closing like when switching between air vent outlets.
  7. Hi all.First time poster here I have a 1990 WD21 Terrano 2.7TD with a heater that does not work.Supply/return hoses are connected.A/C works fine.Blower motor works fine.I'm wondering if the temp control sliding switch is electrical or mechanical?Mine slides back and forth with hardly any resistance except for a very slight ratcheting as you move it.If that's normal then I assume ut's electrically operated.If it's not,then I think a rod/cable has come adrift. Any ideas?Thanks in advance.
