Andrew_Richardson
    Western Australia
Andrew_Richardson's Achievements
  1. The squeel comes from either a loose belt or from air in the power steering pump. I'm guessing a worn out pump would produce a similar sound also. Sent from my SM-G900I using Tapatalk
  2. Also try rocking the car side to side and see if the noise appears, I've had to tweak my sway bar links up a few times. Sent from my SM-G900I using Tapatalk
  3. Interesting. Is yours a td27 diesel? Sent from my SM-G900I using Tapatalk
  4. This sounds similar to a problem that I had with my 1995 terrano. After it had sat in hot sun for a week the alternator and battery lights stayed on for a while but after driving for 5 minutes I heard a clicking sound, most likely from a relay switch under the dash near the fuses and the lights went off. Since then I have taken these relay switches apart and cleaned the switching contacts and haven't had a problem since. Sent from my SM-G900I using Tapatalk
