notroveil
    1992 Pathfinder se
    Missouri
notroveil's Achievements
  1. Not sure what you are asking. Are you asking where to buy a new push control unit or?
  2. I was able to get it mostly loose but there is so little room I wasn't able to disconnect the bar. I'll give it another go tonight. Good news is I was able to move the motor enough to open the mix door and have heat again!
  3. Thanks for the reply. Yes it is auto AC. Ill probably try to remove the motor tonight. Was looking at it last night and looked like a little pita. I was hoping I could move the motor linkage by hand just to open the door but it won't move at all.
  4. The air mix door doesn't seem to be working. It could be the motor but haven't started troubleshooting all that yet, its cold out haha. Does anyone know if you can just manually move the air mix door so it will produce heat? The bar is still attached to the motor but it won't budge if I try to move it by hand. Any idea's?
