			Iamstaypuff
				Posts12
Everything posted by Iamstaypuff
	Still havent fixed it. I thank you all for all your comments and suggestions. Not sure yet if i'm going to try replacing all the hoses. I'm in the process right now of buying a different car. a mercedes benz 300se. I just cant fight this thing anymore. After I pay off the benz i'm just going to sell the pathy as-is. I paid 1600 for the truck and i have put about 1100 in it in parts, i cant do it anymore. Thanks again everybody.
	Mine has no IAC motor
	No ECU is throwing no codes. My uncle seems to think it is the ECU. anyway to test before i go spend another $300?
	Compression, fuel pressure and timing all seem to be in proper working order. Think its just time to sell it?
	Cant really name any spesific tests, cause i dont really know. all lines from the air filter seem to be in their proper position, would like to do compression test. any idea how? my uncle is a mechanic and it seems like he was just throwing parts at it, and now he has just kinda pushed it aside. i need to make this work so i guess im flying solo, so any ideas/instructions are GREATLY appreciated.
	Well as it says in the title, my engine wont ide and i'm tired of throwing money at it. My problem is if i just start it, it dies. now if i start it and hold it at 2500 rpm till just a couple seconds after the fan clutch kicks out, it will do ok... for a while. then after you have been driving long enough to get the engine up to running temp, then say you pull up to stop at a light or you have to slow to turn a corner, it will die. once its warm if you let it drop below 750rpm. dead. put in P or N and restart. I have replaced: Fuel Filter Fuel Pump Ignition Distributor Inanition Coil & Module Throttle body Base Gaskets& Heater Ignition Wires O2 Sensor Injectors Spark plugs Throttle Positioning Sensor Any and all info you can provide would be great! PLEASE HELP! thank you
	"On FM radio, the sound is fine, but after around 3-5 minutes the sound will just fade to nothing. And when playing a CD, with lots of bass, the sound will cut off completely. Turning the radio off and on again only temporarily fixes the issues." this is due to a short. one of your wires is loose. i replaced my speakers with alpine ones, and had same problem. it is cutting out when a bumb big enough makes it short
	i have photos taken just havent had a chance to upload yet
	and im only 20, but old enough to remember.
	Well the owner before me put purple neon lights under it is that a good start? Well after i take the time to get those off, i need grill guards, light bars, new suspention, the works. but no joke it is getting 4 12's in 2 custom boxes to make removal quick and easy if you know the right way, so as not to crimp anything i might want to do
	No fear, STAYPUFF is here. You know that big Marshmallow guy from the old ghostbusters movie? Yea thats me! I'm not new to the streets, but now roll in an 89 XE-V6. So I'm hoping you all can help me with.... please exuse me for this... trick my truck. Yea i know thats bad. Im only the second owner of this pathy and the condition is wondderful. I have every reciept for any and everything done to it. Sadly it is almost completely stock? think you all can help me with that? I have been reading this forum for a bit, and i have faith in you, all of you. Anways hope to have pics up soon.
